It is currently Sun Aug 03, 2025 8:31 am
PostPosted: Wed Nov 19, 2008 1:44 pm
The latest Luthier Tips du Jour video is on the air. The topic is Vacuum Fixtures. I dsicuss the use of vacuum in the shop and show a couple of fixtures I use in my shop.
As always, comments and discussion are invited.
Enjoy!
PostPosted: Wed Nov 19, 2008 2:16 pm
Thanks for that Robbie, very clear, Love your holding device.
One point though, When calculating clamping pressures for the bridge or other items smaller than the fixture, you should be using the area of the bridge not the fixture.
The figure you have calculted is the clamping force of the fixture to the guitar top, the force of the bridge to guitar top will be about a quarter of this.
I don't have any doubt that what you are doing is more than adequate, just the calculations lead the viewer to think all that clamping pressure you quote is on the bridge.
regards
Jeff
PostPosted: Wed Nov 19, 2008 2:21 pm
You are correct Jeff. I should have clarified this.
PostPosted: Wed Nov 19, 2008 10:39 pm
First name: Luc
Last Name: Regnier
Hey Robbie,
Really like those vacuum clamping jigs. Would you happen to have a couple
of drawings on how to build these tools? That would be great, I've got a vacuum pump
and it would be cool to use it as shown.
Thanks - Luc
PostPosted: Thu Nov 20, 2008 9:19 am
Luc,
I don't have any drawings of these jigs. Both of the ones I use in the video are LMI products. If you want to spend some bucks and some time you could make them. Since I am short on time I prefer to just purchase them and get on with building.
PostPosted: Thu Nov 20, 2008 9:10 pm
First name: Luc
Last Name: Regnier
Hi Robbie,
Thanks for the info on the availability of these jigs, didn't realize LMI offered them for sale.
Cheers !
Luc
PostPosted: Fri Nov 21, 2008 6:09 am
Where is the best place to get a vacuum pump...on the cheap? idunno How much compressor capacity do you need for a venture set up.
________________
Jeremy Vonk
PostPosted: Fri Nov 21, 2008 9:28 am
Last Name: Garrish
eBay for vacuum pumps. If you have the compressor capacity, Venturis suck down a LOT faster (which helps a lot with vacuum clamping, as all clamps leak to some degree). You can check out the air requirements at http://qualityvak.com/venturi.html
The Venturis are -really- easy to make, but calibrating the airflow and the airflow/vacuum ratio is a hassle so I'd say it's worth getting one from QV even though you'll laugh when you see how simple the parts are. I use the one that pulls 5.2CFM of vacuum. You can overdrive them a bit if you run them at 100PSI instead of 85, but there are no gains above that.
Bob Garrish
PostPosted: Sat Nov 22, 2008 10:47 am
First name: Danny
Last Name: Vincent
Moving pictures. You have to like them. Although a little more fumbling with the bridge clamps would have made for a good infomercial (tried of your old bridge clamps....) I have dibs on my refrigeration buddies soon to be replaced evac pump. I think it will work.
Have you ever had a problem using wooden bridge pins to glue your wooden bridge to your wood top using wood glue? ;)
Still Watching and Thanks Again,
Danny
PostPosted: Sat Nov 22, 2008 10:49 am
Whoow!
just looked on e bay at pumps
Diaphram, bellows, oil, oil less.
Whats a guy to do?
any recommendations as to type?
Peter
PostPosted: Sat Nov 22, 2008 1:12 pm
Okay, I normally don't consider buying anything from HF that plugs in, but how about this?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98076
My only thought is, if it's for pulling a momentary vacuum on an AC unit, would it hold up for the 45 minutes at a time needed to glue a bridge?
PostPosted: Sat Nov 22, 2008 1:20 pm
Or if a guy had one of those nice units that hold the guitar and swivel all about.
You'd want it to hold indefinatly,not fearing it might release wow7-eyes
Peter
PostPosted: Sat Nov 22, 2008 4:22 pm
Danny
You can wrap the pins in saran wrap. Also, when you remove the bridge clamp to clean out the squeeze out after 10 minutes you can remove the pins. If you don't get happy with the glue you are usually fine.
PostPosted: Sun Nov 23, 2008 9:08 am
Not saying this is a good unit, but pulling a vacuum on an A/C unit is not a momentary thing. I have pulled a vacuum for over an hour, it just depend on the size of the unit and how much moister you want to remove. A good A/C vacuum pump just might cost more.
Todd
PostPosted: Sun Nov 23, 2008 9:41 am
Todd
Okay! Thanks Todd!
PostPosted: Sun Nov 23, 2008 1:33 pm
First name: Chuck
Last Name: Gilbert
Charles Fox wrote a good article about using vacuum in issue #88 of the GAL publication. I basically copied the fixtures he uses in his shop and use a pump designed for automobile A/C use. The system works great and cost less than $200 including the pump. I have run the pump for over 30 minutes at a stretch many times with no issues.
Chuck
Edit - My pump cost around $120 at the local auto supply store.
